JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
So what's stopping someone from putting a 60-1 compressor on a tiny TD05H turbine as long as the wastegate is large enough to flow the additional amount of air the 60-1 generates over a 16G or 20G?The 47 lbs/min from the same turbine on the 68HTA would probably be due to the higher efficiency of the HTA wheel. Increased compressor efficiency will allow more of the exhaust to be wastegated around the turbine at the same airflow. That being said, I've never run or tuned one.
Not saying I disagree with your statement, Kevin....just trying to get some more info!
I've fed my 57 trim from the head for well over 110kl miles and it's as good as it was the day i built it. And the only "special precuations" i've taken with the oiling is using only synthetics (except durinmg new engine break in) and then before putting the drain to the pan I'll run the car for 30 seconds with the drain into a measuring cup and as long as it meets the requirements laid out on the majestic website i call it good and go. I know people that can't keep a turbo for a year without it being junked, i've been on the same one for around 10
and it's fine except for some major compressor wheel wear
