ECMlink Question on Speed Density Setup
Chicken Patty
1,446
19
Jun 26, 2007
Miami, Florida
Hey guys,
Just wondering, I have the ECMTuning Speed Density Bundle with the Speed Density Cable which ties the signal of the 4 Bar MAP to the stock Baro input.
Do these 4 bar MAP sensors still have the same problem as mentioned below?
http://www.ecmtuning.com/wiki/2gbaroinputworkaround
Also, since the bundle wires up the IAT to the factory IAT and the MAP to the Baro input, do I lock the IAT/BARO signal through DSMLink or not?
Quick question, with my configuration, do I still need to use the MDP, or can it be disconnected? Reason is that I'm thinking of getting a SMIM. I don't want to have it drilled for the MDP if I don't need it. Thanks guys. :)
Sent from my iPhone using Tapatalk
There is a fitting you can buy off extreme psi that allows the sensor to be t'd into the brake booster line. You will just have to lengthen the harness to run it under the smim
My question is, can I just not have a MDP period when running on SD?
Thanks, but that's not what I'm looking for. I need to know if I can completely remove my MDP although I have nothing wired into it or assigned as a sensor for my SD setup. It's still in it's stock form, with untouched wiring.
I guess you can, based on what I read, although my MAP sensor is not wired in to the MDP sensor wiring, I guess it shouldn't' be any different? That's what I was unsure off, I have came across those threads you have pointed out a few times, I just wanted someone to actually state if it was possible to eliminate a possibility of me misunderstanding/misreading the info.
Well im doing a rebuild and im looking to run sd soon.
okay...? Anyhow, good choice. Car definitely feels better on SD than it ever did with any MAF I ever ran. ...and I'm referring to driveability. WOT, not really sure as I changed a few things on the setup, but I'm sure it's a difference as well as you don't have any MAF restricting airflow at all.
Ok ive been doing lots of reading on the sd so your question is a good one not sure if i really helped.
From what I've interpreted, yes it can be removed on SD even if not wiring your MAP sensor into it. If someone wishes to come in here and correct me, please do so as I would really appreciate it. :)
