pcnerd
- 0
- Jun 28, 2008
Kingsvlle,
Texas
I was trying to check the timing on my car but I have a question.
This is all on a 2nd GEN Talon TSI AWD.
Is this the timing mark on the block??
This is the timing mark on the sprocket plate correct?
This is how the timing gears should align correct?
Sorry about the crappy pictures, it was super dark and all i had was my iPhone to take the pics.... You would think the 3G would have a better camera..
Anyways...
When I align the sprocket plate timing mark with the timing mark on the block, the cam gears never line up. I turned the engine over by hand, clockwise 15 full rotations just to be sure, each time that I would see that the sprocket timing mark lined up with the mark on the block, I checked the camgears and never once did they line up. They were always quite aways off.
Am I not checking the timing properly? when I was checking the timing before, I was just going by the camgears because I assumed they wouldn't ever line up if the timing was off. What do you all think? I haven't touched the timing. All I did was change the crank angle sensor, battery, and ECU but that didn't require me to remove/adjust the timing belt.
I'm waiting to get ahold of a 1G CAS Pigtail to finish my harness so I can see if this thing will finally start but the timing had me a bit worried...
Sorry for the long post.
Thanks
Anyways...When I align the sprocket plate timing mark with the timing mark on the block, the cam gears never line up. I turned the engine over by hand, clockwise 15 full rotations just to be sure, each time that I would see that the sprocket timing mark lined up with the mark on the block, I checked the camgears and never once did they line up. They were always quite aways off.
Thanks
