question about what might be done???
sup3rfr3ak
43
Apr 30, 2005
Ballwin, Missouri
ok i gotta ? i bought my 95 gst off some dude for 3,000 it has 100k miles and some of u might have seen me post something simular to this previously, but for some reason i got the eci multi 1g intake manifold on their and no clue to wat else done to it but visualy from what i can tell bone stok for some reason its so much stronger and faster then any other stock gst ive ever driven or rode in, but my ? mostly is , is the intake manifold thats on their vs. the stock actual 95 gst intake manifold come with better?
also how can i tell if maybe he put a 1g head on their is their a way to tell without ripping it out? and i was running 15psi on stock bcs
You bought a car off some guy and you don't know whats mods there are or what kind of stuff he has done to the car? :nono: :rolleyes:
LOL not exactly LOL i just made my self sound like a dipsh*t no my friend bought it off this guy in like PA or something HE didnt ask the guy what was done to it i guess etc etc and anyways i bought the car off of him? when i first got it when it was STOCK to me, it has the "eci multi " on the intake manifold and looks larger then anyother 95gst ive ever seen so i looked at 1g engines they have that same intake manifold and ive never seen that on a 2g, so i was jw if its a better IM and what else i could do to see if maybe he swapped heads to? because when i first got it i was beating every gst/gsx around here that had just a few mods
Well here's a few things that will help you know..
- Check and see if a 6 bolt motor was swapped in there.
- Check the turbo you have (housing numbers, blades, etc)
- If theres a boost gauge and MBC, try running 19lbs of boost (if you hit fuel cut, you most likely have stock injectors). If boost spikes down to about 14, it's probably a t-25 (stock 2g turbo).
- Check the fuel pump, see if it whines. You might have a Walbro fuel pump.
- Check the exhaust, see if it looks larger then stock. You should be able to tell by the way it sounds.
There's a start...
