1G Question about fuel tank drain plug?
DannyE
104
22
Dec 2, 2016
Martinsburg, West Virginia
Hey guy's, I went to drain my fuel tank (93 laser fwd) and when I removed the drain bolt it was barely dripping. So I used a light to check the orifice and it appeared clogged. I then took a scratch all to try and unclog it, as I was pushing up a little something gave way and the fuel came poring out. After draining I then went to insert the drain bolt and there was no threads in the orifice? I do believe I pushed the threaded portion into the tank while trying to unclog it. Is the threaded portion connected to the pump in any way? and can I just re position it to re install the drain bolt. Thanks in advance for all of the help.
The threaded portion is not connected to the fuel pump in any way. The threaded part should be spot welded to the tank.
You can try taking the fuel pump off and taking a look inside to see if the welds really broke
No it's not spot welded, when I took a look today I seen no evidence of spot welds, the bracket seems to be staked to the tank. I do believe the bolt is to hold the bracket that is connected to the fuel pump. Well I guess I will be removing the fuel pump and taking a look will also probably weld on a bung for a real drain plug as well. Thanks for all of the help guys, I really appreciate it.
Yeah I think your right, hopefully when I remove that fuel pump I don't have any issues with those little studs. I will make sure to report back when done. Thanks again for all of the help fellas.
Alright well I removed the fuel pump and like with most older cars ran into a few issues along the way. The first surprise I noticed was everything on the outside looked immaculate, no rust anywhere and the fuel line was removed with no issues as well. When in the fuel tank I noticed quite a bit of rust and I also noticed that the fuel pump bracket was rusted and the piece that attached tho the bottom of the tank broke off. I will be making a stainless fuel pump bracket and I will most likely be fabing up a aluminum or stainless fuel tank so that this never happens again. Thanks again for all of the help fellas.
