Q on brembo drilled rotors w/ HP pads
Spector5
274
6
Jul 31, 2011
holland, Michigan
So I read that its not recommend to use brembos drilled rotors with a set of high performance compound pad? Was wondering why they dont recommend it, and what problems would it cause if you did run a set up with those components?
The holes in the rotors increase stress concentration on the rotors and they tend to crank around the holes. I have ran several drilled rotors and they all had cracks around the holes. None of them failed or but maybe in a track environment they would have. I wouldnt buy them
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
