- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- -FP ported 68hta(v1)
-FP ex. Manifold
-ETS 7" FMIC kit
-Greddy type "s" BOV
-TurboSmart MBC
-3" SLS intlet
-K&N Air filter
-Wally 255hp rewired
-FIC 850cc
-Megan o2 housing
-Megan DP & test pipe
-Thermal R&D catback
-MSD plug wires
- Mods-Engine
- 2.3l stroker
-eagle 100mm chromoly crank
-eagle H beam rods
-Airas forged pistons
-Manley rod and main bearings
-ARP main & head studs
-Piston cooling nozzle delete
-Kiggly HLA
-Revised lifters
-COMP 272 cams
-BSE kit
-Gates timing belt tensioner
-Evo timing belt
- Mods-EMS & Logging
- -DSMLink w/ speed density
-AEM UEGO wb
-AEM "boost" gauge
- Mods-Drivetrain
- -Fidanza light weight flywheel
-ACT 2600
- Mods-Handling
- -KYB gr2 struts
-Megan lowering springs
-Brembo drilled front rotors
-Hawk pads
-17" Tenzo R rims w/ Nankang tires
- Background
- Purchased the car in 2006 while in high school. Blew the engine up 6 months after purchase as most young dumb kids with a dsm would and will do. Learned and grew a lot since then. Made bad mod & part decisions, and took time to correct my uneducated decisions. I never seem to be happy with even work is done to it. I've
Redone the wiring at least three times. Currently, the engine and trans is out to redo arrange and clean the engine bay up. Also, building a wiring harness from scratch as the 91' oe wiring has seen better days.
