Purchasing a Talon TSI AWD, good deal?
Panchoelkatch
124
5
Jun 4, 2014
Lemoore, California
I'm getting a pretty sweet deal on a 1995 Talon TSI AWD. All stock except lowering springs and minor 2G conversion (headlights and tail)
Has 80k miles looks in decent condition but here's the bad part he says the pressure plate went out after a shitty clutch replacement. Car will turn on and idle fine, but clutch won't let gears engage while car is on. They will go in when car is off.
I'm trading an xbox one and $300. It has 300$ in DMV fees what do you guys think?
It sounds like a sweet deal to me for that price. $300 and a xbox? I don't like xboxs and actually don't play very many video games so I would jump on it. But who knows what all that could be wrong with it. Ifor you're willing and able to fix it, I'd do it. Pics if you get a chance
No rust, and what would you guys say is a common issue with these cars that I should look for? Obviously drivetrain is a big one, but I know the clutch /pressure plate is bad. Any way to check if the tranny is bad?
check for thrust endplay when you pull trannsmission. Pull plugs check there condition for normal burn. Do ALL mantanace, such as timing belt bs shaft belt, put a decent clutch in, it may not go into gear because bad clutch pedal assbly adjustment.
I would jump on it if nothing else to turn a profit.
If you can, check the wiring for tampering. If it starts having electrical issues, it may be worth it to invest in whole new harnesses or even get a new car. I'm getting sick of people who think that they need to rewire the whole car and then nothing works.
good choice!!, just do maintenance past owners don't seem to care a lot about maintenance, but at half the mileage i have, you're golden.
So were at a point where my cousin thinks it's the transfer case because gears won't go in while it's on.
Here's the story...it has literally a brand new clutch installed by the previous shop, it breaks down 2 weeks after. The previous owner said it didn't even need the clutch but he just wanted a fresh clutch. Needless to say I think the shop did a shitty installation and the pressure plate have out.
I found receipts where literally it's had a brand new timing belt installed, ball joints, alignments , balance shaft belt. So the car had been recently maintained. Doesn't even have 400 miles on all these parts
looks good man i just recently bought a 99 gsx and im in the process of replacing the head gasket. i have been told they are pretty notorious for blowing head gaskets but over all cant beat the deal do it.
Sounds like a good deal if you're looking to start a build, but the car may have more issues than just a clutch if he's willing to trade it for an xbox hahah
    • george bromwell
    • pma1123
    • Sdcryan1
