pulleys for GSX... Is this true??
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
i was thinking of buying the 4 pecie pulley set from machv.com: http://machv.com/macvalpulkit.html
for my 98 GSX and heard this from another post""Okay, I went to my local import shop and I asked about an Underdrive pulley to see if they could install it for me and they reacted incredibly negatively. They said that the harmonic dampaner would be taken out and the underdrive puley would basically act like a tuning fork on your teeth making engine parts fail faster. """"I think the guy may have been referring to a turbo engine.""
So is this true?? will i have probelms (alternator pulley, power steering pulley, and water pump pulley.,underdrive crank pulley (undampened))
If there is no hamonic balancer the engine COULD vibrate. It all depends on the motor itsefl. Soem people never have problems with the Bshaft removal becasue there motor just ended up more balanced then the guy next to him. Same applies here. I would only use that pulley on a rebuilt motor that was very balanced.
Michael
:talon: :laser:
how do i know if their is a hamonic balancer??? and what pulley woundn't be good to get at out the 4?
the crank pulley is the pulley that you would not want to install
IMO the pulley set just isn't worth it, that money would be better suited on other items
this is straight from their web site:
But for a street-driven car, one that you might want to last a couple of hundred thousand miles, we do not recommend using a pulley without a harmonic dampener.
what does that mean" pulley without a harmonic dampener" would i be save w/ the other 3 pullies????
