dtshelton
- 0
- Mar 27, 2006
blacksburg,
Virginia
i just got finished putting on a newly machined head and new oem head gasket with arp studs on my 92 gsx. started it up and it is puffing white smoke(coolant i think) out the exhaust after it warms up. i took it for a short drive and it seems like it runs decent when above idle but i am losing coolant from monitoring the overflow tank. so i did a compression test and it was 160-160-160-90. i did a wet test and no change to the 90 cyclinder value so i figure its not the rings. i think its the head gasket i just put on but not positive. i torqued it down to 80lbs in steps(maybe too low???) with moly lube and now i'm at a standstill. should i pressurize the cooling system and/or leak down test to see where the coolant/compression is getting lost? this was my first time doing anything major to my motor and i thought i did everything right but now i am running into problems with white smoke and also the idle is kind of rough. it sort of sounds like a motor with a bigger cam in it. any help would be appreciated. this is my only car and it needs to be fixed fast. thanks.
