compression and white smoke and head gasket.
danielkile
47
Jun 11, 2010
York, Pennsylvania
Hi, so im blowing white smoke but I did a compression test and im at 150-155 thruogh all 4 cylinders buttttt my coolent overflow looks a little brownish/rusty butttt I dont have any gunk in my oil or collecting on the oil cap... help me please...
A compression test won't always reveal a blown head gasket. Have you drained your oil to see if there is coolant in it, or done a leakdown test?
White smoke is burning coolant. You need to do a leak down test to verify how coolant is entering the combustion chamber and get back to us with your results. Are you familiar with a leak down test? If not will post a link when I find it.
FYI regardless of how the coolant is entering the cylinder the engine is going to have to come out to be repaired, actually scratch that you can repair a head gasket without removing engine completely. But be prepared for some work ahead
this is the first one I found on leak down tests which is actually a really informative video http://www.youtube.com/watch?v=GvG22YMOzUI
