pte 50trim is on the car, 2 questions
saxrulez
83
Feb 4, 2004
Fayetteville, North Carolina
I've got the turbo on the car now. 2 quick questions that I need help with right now.
The turbo came with a hose running from the compressor housing to the wastegate actuator, do I just cut that, plug up the compressor side and run the hose to the MBC?
2nd question, how do most people plug the bolt in the head where the old turbo was getting oil?
I run my BC from the turbo compressor, used a better line then what came on the turbo though.
I plugged the hole in the head with a cut down bolt from the hardware store. Its like 8 x 1.25 i think.
yes just use a bolt to plug the hole but be sure you put a crush washer on it. as for the boost controller, yes you can either use that source or plug it and use a better source (intake manifold)
