PTE 50 trim BB question
That is the compressor boost course. That goes to your MBC or you can cover it up and take the boost source from the intake manifold which is what you should do anyway.
Also do i have to bend these like the stocks water lines? and i still dont know what do do will that hole???? help
I didn't want to bend those lines and end up with a kink, so I just cut off what I didn't need with a hack-saw/dremel and put rubber lines on the end to make the curves I needed.
As for the hole under your turbo, as posted before that is the boost source. If you don't want to use it, find a nipple that will thread into it and cap it off.
Its probably 1/8" or 1/4" NPT thread. Either install a brabed fitting and use it as your pressure source for your wastegate or if you already have a source in your lower ic pipe just get an NPT plug in the correct size.
Can i just put jb weld on that hole on the turbo?
Why would you want to do that? This is perfect for your mbc pressure source, leave the BOV line alone.
I have an EBC
Then I would just install a 1/8npt to 1/8" fitting and cap it off, much cleaner in case if you want sell the turbo later.
Is anyone else annoyed with the fact that his BB turbo didn't come with the pressure source nipple? I'll tell you what, If I paid 1k (which I did) for a turbo, it better come with everything it's supposed to come with.
daren_p said:
So what does this mean? A EBC still needs a pressure source :confused:
I know i was just replaying to what oldman said."This is perfect for your mbc pressure source" just saying i have a ebc
Yes I understand that you were replying to oldman saying this makes the perfect pressure source for a mbc. It sounded like you are implying that because you have an EBC that you don't need a pressure source? or were you just saying you have a ebc instead of a mbc? Either way you should be using this port as your pressure source, unless of course you already have a pressure tap right after the turbo or in the lower ic pipe. What are you using for the source right now?
