talonDSMerr
- 788
- 21
- Aug 19, 2007
Greenwood,
Indiana
To quench this 2.3's thirst for E85, I picked up a set of FIC high-Z 1680cc injectors. The idle on these should be near stock!
My hx35 oil drain setup is shown here. I fitted a pipe to a drain flange, had an EMT conduit sweep welded to the oil pan, and connected them both with Vibrant high-temp silicone hose. I clamped both ends with t-bolt clamps (not shown here). The smallest inside diameter seen in the oil drain is 0.777". Big enough for Holset's spec.
Bolted the Punishment Racing divided T3 manifold up and it sure looks nice. I think this combo (2.3L, Cyclone intake manifold, proper divided hx35) will make for a fantastic driving experience.
Finally assembled, complete longblock.
Day of engine drop. Bolted on XACT chromoly flywheel with new loctited flywheel bolts.
My clutch of choice sent from TMZ performance. A South Bend SS-X pressure plate and TZ kevlar clutch disc.
Transmission bolted back up. To handle the torque I may see from this setup, the transmission has been rebuilt with an EvoIII gearset, input shaft, and a 4 spider center differential. New OEM clutch fork, pivot ball, and throwout bearing are also installed. Clutch fork sits slightly over to the slave cylinder so shimming the pivot ball was not needed.
Engine and transmission finally going back home! I had to readjust the hoist's boom a couple times to get it right. Bolted down to Prothane motor mounts and a solid front roll stop. Rear mount first, front second, transmission third, and driver side mount last. Everything went pretty smoothly.
Follow part 3 of this build here
Did you ahve to go to animal testing to afford that puppy?
