talonDSMerr
- 788
- 21
- Aug 19, 2007
Greenwood,
Indiana
This is my custom v-band o2/downpipe for the Holset's non-wastegated 12cm^2 turbine housing. I performed all the cutting and fitting, taped it together, then took it to my local welder to finish the job. Boy does he do good work
Not the funnest part of the build, but, I am very proud of this piece. It definitely took many hours to get the fitment perfect, and worth every effort.
Bolted everything back up, and it started on the 2nd try on E85
The engine bay isn't the prettiest thing to look at by far, but it serves its purpose to a tee.
As of now, the engine is being broken in, but I notice it is running a little hot so I will be adding a 10" flex-a-lite slim fan to the driver side radiator. The paint on my hood is also beginning to bubble from the heat given off by the turbo manifold, so some DEI lava rock heat wrap and a turbo blanket are on the way as well.
As far as initial impressions? Absolutely amazing.
Read Part 1 of this build here
Read Part 2 of this build here
