Problems!
Gerg
124
4
Dec 19, 2012
Cheyenne, Wyoming
Ok so i picked up this 90 tsi today. Stock motor, 20g, stock injectors, fpr, boost gauge, wideband, supposedly has a 255 however i haven't had time to check. I think the injectors are bad and it has some serious fuel cut. The car will go into a limp mode occasionaly when not in boost, sometimes it stays like that until you rev it to a higher rpm. Im working on getting ecmlink and injectors to stop the fuel cut (if thats what it is) i just need advice on whether or not this sounds like fuel cut or another issue. The starter is also out i believe. Thanks for your time and input!
Use a descriptive thread title when starting a new thread as listed in the rules you agreed to when joining the site. Instead of "Problems!", which sucks, try again using something that is searchable as well as more enticing to gain attention and possibly more advice from members viewing the forums.
