1G Power steering pump removal and delete.
scott90gsx420
603
5
Sep 25, 2010
nampa, Idaho
Ok guys so ive gotten tired of my power steering pump in the car.. Ive read around a lot and just want some clear thoughts on whether or not to remove it.
The pump leaks a bit due to the bolt on the bottom being stripped. The lines leak in the back somewhere and im just plain tires of going through a qt. of fluid a month(tops sometimes its faster.) Ive use stop leak all that and its just getting worse..
I want thoughts on removing it? Should i remove it or just deal with it LOL?? my old crx had no PS so i know it will make the steering tighter and stuff but i want to know if il run into any issues or what i should/shouldn't do when removing it..
Thanks guys.
Pretty sure it's the curved line and that one that looks like push lock, what do i cut the lines with? Can i just cut them at the rubber part where the regulator and break resivours are?
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
