Potential of 54mm inducer H1c Wheel
turboglenn
6,375
123
Nov 5, 2007
RIpley, West Virginia
I havebeen searching google and other forums a while and no direct results, only opinions. HAs anyone here pushed the 54mm h1c wheel into thr 30psi range and really put a good tune on it? If so what was the power output?
I can upgrade my h1c to a 54mm wheel and housing for a good deal right now and in the future will probably put the 58 or 60mm wheek with MWE equipped housing on it (i love the upgrades available onthis thing)
Anyway, I don't wan to run it at all with the 50mminducer, and was wondering if the 54 would even be worth the upgrade (just bolts on but needs a balance)
Wondering what lb/min it's good for andwhat have some real world reasults been?
Also, my holset is one that's balanced as an assembly (and my local shop balances everything as assemblys) Where can i get my parts component balanced so that swapping and experimenting won't be costing me an arm and a leg (balance went from 35 to 65 locally..jeeesus!!!)
Right now i'm choossin between a ball bearing old shcool 57trim wheel, a JB 50 trim setup, or the 54mm holset h1c with t3 .63 a/r housing (didn't need the big ass 67mm unit really)
i've read all that, which is why i was asking for first hand experience from anyone running one, or that has a friend runnign and loggingone, thanks thugh
From what I have seen you and I will be the first to use the big h1c with a machined t3 housing so our results will be some of the first. If the guesstimate is correct in the holset thread then at 30 psi I would think you would be around 450-500whp. But that is just speculation as most people just opt for the hx35 instead. My goal is 450awhp around 26psi on e85...we shall see if I actually get there
I was getting around 48lbs per min on mine logged in Link with a BEP .71 T3 housing. Still have it kicking around if your looking
28ish dropping a bit up top. Figured I had wrung it for all it was worth at that point :)
