MNGSX
- 2,533
- 25
- Mar 30, 2003
Bloomington,
Minnesota
herostar said:I don't see where it says it'll fit a dsm...
The pictures and writing obviously show it on an EVO 4g63 because the timing belt is on the wrong side and the turbo faces the wrong direction. It talks about EVO's but doesn't mention a DSM. That'd be pretty sweet if the started making them for DSM's though.
not an evo 7/8/9 as far as I'm aware of......MNGSX said:And nobody has ever used a production EVO manifold on a DSM before right?
definitiveno said:not an evo 7/8/9 as far as I'm aware of......
Flip the turbo around?suicidal2af said:Bolts right on. Only problem is the compressor housing and your alternator being a little too friendly.
Are you trying to make me look like a horses ass?1fast97gsx said:Are you joking?
definitiveno said:Are you trying to make me look like a horses ass?
You don't have to be a dick about it.MNGSX said:And nobody has ever used a production EVO manifold on a DSM before right?
primarily for the serious 2.5 litre engine, it will deliver 14.5 psi by 4,500 RPM in that application.
Cool, I don't have a turbo, o2 housing, evo manifold right in front of me to check it all out so I am kind of dependant on people who have to tell me what it will look like1fast97gsx said:WTF Take a look at a turbo from either the compressor inlet or the exhaust outlet. Now look to see where the exhaust inlet is positioned on the x axis. See how it's not perfectly centered? If you flip the turbo it would push the whole thing out the opposite way most of it goes now. Not to mention the lower intercooler pipe, intake pipe, O2 housing / downpipe and oil lines will not bolt right up anymore.
