Post your 1g install pics
You could try mounting the solenoids down on the backside of the block, underneath the intake manifold. I don't know how much clearance there is on a 1g.
Im going to be getting a Wet kit for my 1G, to many sissy on here dont like to spray.
Anyone have a hidden kit? Ive go a few places and ares ive seen that could be used.
starion4g63 said:
here you go. cant see it under the intake. i made the distribution blocks myself.
That thing is SICK!! How much would you charge to do one sometime for me, LOL.
Zex wet kit install. I ran the fuel supply off the regulator. I also routed the purge to the intercooler...
Zex wet kit. should get my little 14B FWD into the 12's.
new toy
Does anyone have pictures of a hidden install. Im thinking if going with a direct port kit and running a 150 shot on a built 2.3L engine and GT35R and controlled by EMS.
The problem I run into is that everything must be hidden because here in Canada, Nitrous is illegal on a street car. I was thinking of cutting a big section of foam from the back seat cushion and then cutting the sheet metal and creating a box that would sit lower. Running the nitrous under everything. The problem I run into is the engine bay. How would I make it so that NOTHING shows.
If anyone has any pictures it would be extremely helpful, along with any advice.
One of my friends cut the bottom out of a medium sized duffel bag and just put it over the bottle in his SHO. another set up is to cut out the bottom of a small tool box and have it in there.
I did theh duffle bag trick in my mustang. I just bolted the mounts right throught the bottom of it. Then to hide teh rest i covered all the braided lines in black wire looming. I put the nozzle on the underside of the TB inlet to where you could barely see it. Most people couldn't tell untill i was passing them sideways in third gear :D
    • Sdcryan1
