Post your 1g install pics
93jdmlaser
242
Sep 1, 2004
Cherry Hill, New Jersey
I searched for pics of 1g install and only found a few. Theres alot of 2gs pics but none for the 1g guys. I just got my wet kit and I want to know where everyone else with a 1g mounted their bottle and solenoids. Ill post up when mines done. Thanks
Got the bottle mounted. Now I got to find where I wanna put the soleniods. 1g guys post up where you put your setup. Thanks. More pics to come.
Mine is a really crappy setup. I just wanted to get it installed then I cleaned it up a bunch.
Bottle Mounted in the back like everyone else.
Here is the line comming out of the back. I ran it through the drain plug and then zip tied it to the fuel lines. NX instructions actually recommend this.
Here's the shark nozzle going into my Intake. 4-6 inches from the TB. Yes I have duct tape on my intake tube. I need a new, better one.
Here's the fuel line I cut to splice into.
Here's the T fitting going to my injectors and my fuel selnoid for the nitrous. I really dont like this.
Heres the selenoids just kinda resting on top of everything. Needs cleaned up, but it works.
just got my bottle done
looks like you cut the line after the regulator (ie the return) thats a no-no
Impossible, I know for a fact I'm getting a mixture of fuel and nitrous. When I first used the kit I had the nitrous line over tightened onto the nitrous solenoid. So when I sprayed I got no nitrous and all fuel and it flooded the engine. Can you show me pictures of where you have yours spliced? I'd rather be a little more certain.
Thanks
Thanks
he is right you tapped into the return line, you need to tap into the feed line.
I posted the install on my other car before but heres the install on the car im driving now.
Ignore my fuel line I havent gotten around to moving it yet.
here you go. cant see it under the intake. i made the distribution blocks myself.
thanks here is some more
it just points down in front of the trans with a 12inch k&n
actually it looks good in person. it is powder coated with flake in it. i have had a polished cover on it but it didnt look right. this is just my dirty little street/track car no show and go.
90 GST
Eary pics last summer, single fogger wet, 50 shot.
DUDE i just nutted in my paints thats the cleanist dsm engine bay EVER. I'm from Jersey and so are you it was ment to be now go get me a ring!!!!
Thanks man. The car just got a bigger turbo and will be at Imp for dyno day on 3-1-06. If the weather is good I might go tune it tonight. Hope the new turbo works without the juice,but if it doesnt its jetted for 100hp and ready to go.
Does anyone have pictures of a hidden install. Im thinking if going with a direct port kit and running a 150 shot on a built 2.3L engine and GT35R and controlled by EMS.
The problem I run into is that everything must be hidden because here in Canada, Nitrous is illegal on a street car. I was thinking of cutting a big section of foam from the back seat cushion and then cutting the sheet metal and creating a box that would sit lower. Running the nitrous under everything. The problem I run into is the engine bay. How would I make it so that NOTHING shows.
If anyone has any pictures it would be extremely helpful, along with any advice.
