Possibly buying motor, tell me what you think?
PRESSURIZED
207
3
Jul 8, 2003
SoCal, Hawaii
Okay, I need another 6 bolt for my 95 GSX nd was highly considering purchasing this motor.
I currently have a 50 Trim turbo that I will be using (along with dsmlink)
Tell me what you think of this motor and if it is worth $1500.
will it spool super slow? and howm much power (roughly) do you think it will hold? thanks a LOT.
wiseco 8:3:1 pistons, eagle h beam rods, arp head studs and rod bolts. all clevite bearings, polished crank. mitsubishi 4 layer head gasket.
the head was freshly rebuilt with all new (stock valves springs and retainers) and it has comp 101300 cams. the head was completly rebuilt and hot tanked as well. also had all new timing belt, oil pump, water pump and balance shaft eliminator kit as well
GSX93DSM said:
If it has got what you says it has it is to me. Make sure the valve springs can handle the cams. Make sure you check it out reall good before you buy it.
Thats wht I was wondering. The comp cams seem a little much for the stock valve springs, but I dont know.
