plugs not plugged into anything...HELP!
I'm pretty sure that first one is the plug for the A/C fan, which it looks like you removed it, so you won't need that.
I don't know about the second. I don't remember that one.
ok that helps solve the first one...
Third one in the first post looks like the Crankshaft position sensor, First in second post is not used and the last one goes to a vacuum solenoid which it looks like the vacuum lines have been removed. Ill get back to you with the name of it.
where do i plug the third one into? and what about the last one? what do i have to get or do to fix that
EDIT: its the EGR solenoid.. But a better thing for you is this thread>> http://www.dsmtuners.com/forums/articles-electrical-wiring/298047-2g-engine-bay-electrical-connections.html
the guy i bought it from removed the emissions system...what should i do with the plugs that dont go anywhere?
^^ Last pic is the noise condenser (capacitor)
You can either leave it the way it is and thow CEL codes or go to a local junkyard and pull the necessary parts you need and put them back in!
All of the connectors in the engine bay can only plug into one thing. Look around for more open plugs near where those ones are located. You should be able to find them.
There is ONE PLUG on the 2gb that will fit in another, and thats the crank sensor. It fits into the A/C plug. Found that out the hard way :banghead:
you remember those box things as a kid where you put the shapes into it.. Well I like to play that game when reconnecting the wiring harness.. :hellyeah:
LOL yea i was gonna say they look exactly alike
i have...believe me...ive had the car for a couple weeks ive been looking i cant seem to find anything...
Hope these will help...note the first number in the (xxx), under the connector number is the number of wires going into the plug, the second letter is the color of the plug. So (2-B) means there are two wires in a black plug. Look at the diagrams along with where the plug is located. Note that you may need to look on another page of the diagram to find the name of the plug. Hope these help...
