Wideband guage not reading anything
ez_ed23
Apr 10, 2007
Pittsburgh, Pennsylvania
It's an AEM analog wideband gauge
Title basically says it all.. two blacks to ground, two reds to constant 12v source, white to pin#4, and pink to switch..
but i start the car any nothing happens with the gauge.. no movement at all. its in the front o2 sensor spot. set it up in ecm link checked off sim narrowband.
any help or suggestions would really be appreciated!:confused:
yes either your grounds are bad or your power wires are not hooked up right. I would go back and double check your wiring and use a test light on where ever you hooked them up for to power to make sure those are even power wires your hooking them up into
hooked up to the battery, grounded to the same spot as the battery
i mean two red wires on right are power, two blacks on left are ground, and white goes to ecu pin #4.
Maybe it's wired wrong as far as the gauge, not too sure on that one. I noticed that you said it's in the front O2 sensor spot. I think it explains in the instructions that a separate bung needs to be welded on, around, 32 inches downstream of the turbo and before the CAT, I believe. The wideband O2 sensor is placed in that bung. If this is not done the wideband readings will be incorrect. I think there is a video for install on AEM's website if it's not in the manual.
thank you for the thought. but... a second bung does not HAVE TO be welded in place.. and you actually get a better reading on A/F ratio with the sensor in the front o2 spot.. that why (and im not sure about previous versions) dsm link v3 has a sim for the factory o2 sensor. so its not needed. ill stay updated after i try a few different things tomorrow. bought a pigtail for my fuse box inside the car, maybe ill have luck with that
Ok I'm stumped... Maybe the gauge itself is bad or something happened to it while it was in my trunk.. LoL
