Please review idle dsmlink log.
Why do you have LC-1 set on two different inputs? How do you have it wired up? This is causing an issue with how your sensor is being logged.
Your AirflowPerRev is a bit higher than it should be. With stock cams, you shoot for .26, but since you have 272's, I'd say .28 would be good. You might be able to hit .26 depending on the settings, but either way, it's not far off.
Your ISCPosition is really high. This should be 30 at idle.
Your battery is pretty low - it's reading just above 12v. This should be at least mid-high 13's or in the 14's.
Your AFR of <10 certainly looks out of the ordinary unless you're running ethanol. Other than that, airflow and MAFRaw at idle are a little high (are you still at 2.0L?) but not anything alarming. Your intake temp is very high (110) as well.
Is there something we should be looking out for?
I have an automatic, and stock cams. My wishlist says 272's :). I think I might have messed something up when I did my TB rebuild to make my ISC position so high :/
