2G Please review DSMlink log (No Start)
Kdouglas89
436
11
Jul 8, 2013
Davenport, Iowa
95 TSI with 97 ECU - Speed Density, FIC 1120's, 43.5 Fuel pressure
Cranks and bucks like it wants to start, but doesn't crank fully over. Makes a weird winding type noise while cranking. Have tried multiple plug orders, currently its at 4-1-2-3 from right to left. Noticed at cranking, the battery drops quite a bit.
Anything else stand out on the log to you guys?
Thanks a ton
I don't see much offhand other than you need to put the battery on a charger while you wait for more input and double check it's connectors. The voltage is dropping down as low as 7v while cranking and I don't think the ECU will try to do much below 9v.
That’s what I was thinking. It’s been on the charger since I tried, but wasn’t sure if I had a bad battery or not. Was gonna go out tomorrow to buy a new one to see what it looked like then
