Dsmlink log please help
crazyquik22023
641
6
Sep 14, 2008
Akron, Ohio
Ok so my car runs badly.. can't idle w/o me giving it gas. also i think there is something wrong with my MAF. Here is a log with the car off
the maf is getting some kind of reading at 14 hz but here is the log with the car running
the maf does not get any kind of reading. Does anybody know why this would be??? also could this cause the AFR to be 0:1??? thanks
Well, it looks like your MAF is unplugged, your o2 values are WAY high for idle (oscillating between .1 volts and 1.02 volts with no throttle input), your coolant temp is showing nearly 230* which seems high to me as well, and your TPS could use some calibration as well. I am a newb to link, though, so i would post it on the link forums and see what kind of help the more advanced users can give you.
check your ecu my car did the same thing turned out my 98 gsx ecu was toast just ordered a chipped eprom. have a buddy come over and swap ecus for a try.
good luck
the maf is not unplugged and how would it be getting a reading of 14hz when the car is off??
good luck
ECU is brand new from ECMTuning so i really doubt that is the problem
