dsmlink first e85 log. please help out with pointers
M1L3S
132
Apr 1, 2012
maple grove, Minnesota
hey guys, first idle log with e85 and running the 1600cc injectors
please give me your thoughts and critiques.
You need to:
  • Car is idling way too high
  • Adjust your TPS so it is at 0% and .63v when you are not on it, it is currently 2% and .71v
  • Get the car to enable idle switch (By getting to 0% tps) and see if it will idle at target rpm, if not BLT the setup and look for leaks.
  • You are not logging your Wideband
  • Injectors are scaled way wrong (I've 2150cc at 43.5psi scaled at 1280 on E85)
Once it is idling right, then start adjusting MAFComp to reach around .25-.27 airperrev and dial in the injectors correctly. You can tell they are way off since when you start moving it wants fuel.
Also post up in your signature what modifications you have.
