DSMlink first log, help me....lol.
twinsnails
93
Mar 29, 2009
Northwood, New Hampshire
Hey guys I am way new to DSMlink not sure what the values mean at all. I got my car I know it had it could never get it running on my mac (V2) not sure it can run on it. Now I just got a little netbook for this. So i got this thing hooked up and I did a simple log of just idle and a little rev I am going to post it. Just tell me what you think because I dont know what is good or bad.
Thanks to whoever takes a look.
I can't see any of your settings, it says "command timed out"
Anywho your AirFlowPerRev is too high at idle, it should be around .27
And your front 02 sensor looks like it's almost dead. No voltage until you rev it.
Also log MafRaw and tps, ltft lo and ltft mid and stft.
Cruise around for a bit and do a 3rd gear pull and post that log. (of the pull only)
Alright thanks ill try and figure that stuff out LOL, I have v2, can I do all of what you told me to log.
Update, with the v3 still no 3d gear pull but if someone can take a look at the ecu config from this log. The MAF Clamp and Fuel tabs I do not know why they would be like that. Probably why my Airflow is high. Thanks again to whoever takes a look, much appreciated thanks.
If you go to DSMLink and set up an account to enter the forum, you can get alot of feed back and look into the wiki part as well. It's help me alot with the stuff i don't know about.
Here is my log.. you want to make stuff smooth.. Please log some kind of pull and try to log the things im logging..
Edit: i I just looked at that pull i did and a 2.5sec 70-90 awd isn't bad LOL
