Please help me identify these 3 parts just above my water pump.
4gfun
Supporting VIP
2,009
56
Dec 10, 2007
Ask Me, Virginia
I was replacing my water pump and wanted to see why I couldn't get it back on. Little did I realize that it was because I needed to press the water pipe first.
To better understand what I was doing, I took the long road of removing all of the brackets (and what looks to be a heat shield) along the way.
I'd like to get my torque specs right so I'd like to know the proper name of these parts so I can go look them up.
Thanks for all of your help as usual.
Thanks so far everyone. I'll take more pics of what seems to be a 2g trigger plate. This part faces the exhaust manifold IIRC.
Appreciated.
The third part is definitely not a trigger plate. You would've had to take the crank sprocket off to get at that. This is what a trigger plate looks like.
Possibly the factory PS pump heat shield? That is in the same area as those other parts and faces the exhaust manifold.
Yes its a stock power steering heat pump shield.
One is the power steering pump looks to be 1g, next is a motor mount bracket for a 1g as well, third is the heat shield for the power steering pump. It attaches to the bracket with a bolt. All of those are in the same area.
In this link: http://www.dsmtuners.com/forums/articles-miscellaneous/437697-what-size-bolt-nut-stud-fastener-1g-version.html
You would be after:
-Power Steering Engine Mount Bracket to Engine (washer assembled)
-Power Steering Mounting Bracket to Engine Mount Bracket (washer assembled, Phillip’s head on hex top)
-Power Steering Pump Oil Heat Shield (Aluminum Plate) Flange Nut
You would be after:
Too funny, since I use that link all the time. Thanks so much for creating it.
:hellyeah:
When confused, I referred to the grade of bolts and bolt length (compared to my dial calipers) to narrow it down.
