Help me identify these injectors!!
white7g
May 7, 2015
Charleston, South Carolina
got these from a friend that parted out a running 1g he doesn't know what size they are and I cant find any info on them. they have 4 different numbers on them, 16758/87255, 3155/77255, 11258/77255, and 15658/87255. google searched the numbers and came up with nothing thank you for the help!
I think they are a GM fuel injector, I had a set before the FIC ones I have now and they were like 42 lb injectors? http://www.injectorwarehouse.com/injectors/gmc/mp3058.htm
found info out the are a Delphi/Rochester 65lb per hour or 680cc injector this build will be a 2.4l with forged internals and 1g cylinder head are these injectors worth installing or look for something different. if so is there somewhere I can send them to get flow tested and cleaned. thank you!
