Piping Size?!
Dark DSM
164
7
Nov 3, 2003
Roseville, Michigan
OK now in trying to figure things out, what is the ideal size of piping to use for a turbo system. I was going to go with 2.5 inch, should that ok, or should it be3" Let me know. Thanks:confused:
2.5" is more than enough. Many of us run 2.25" piping, and those of us who don't, have 2.5" pipes. 3" is overkill.
Like Paul said 2.25" is standard for IC pipes, however a select few have 2". Assuming that's what you're talking about.
As for exhaust 2.5" will do, but 3" is recommended.(incase you were referring to this)
I have 2 inch ic pipes and no problem. The bigger the pipes the more lag and pressure drop you will have. Not a whole lot of difference but alittle. Like the difference between spooling at 3000 or 3200 rpm. I would not go bigger then 2.5 on a four cylinder. The supra guys go real big sometimes. I have heard of 4 inch on those bad boys.
Yeah, I saw a Supra with absolutely huge piping when I went to get mine made. It had to have been at least 3" IC piping with a 4" exhaust. Those sizes are definitely not recommended for our little cars. 2.5" IC pipes with a 3" exhaust is the point where you'll start realizing diminishing returns and/or performance losses.
2.5" all around for me...turbo compressor outlet is only 2", but a silicone transition elbow solved that problem nice and quick.
If you're a believer of Corky Bell, he suggests a pipe size that will promote an internal airspeed of < .4 Mach (304MPH) at which point is the onset of excess drag.
Taking the calculations from this Honda-Tech thread based on a .4 Mmach limit in a straight pipe the maximum recommended airflow for each sized pipe:
2.00" = 585 cfm max (~400HP*)
2.25" = 740 cfm max (~500HP*)
2.50" = 913 cfm max (~600HP*)
2.75" = 1100 cfm max (~750HP*)
3.00" = 1300 cfm max (~900HP*)
* using cfm to lb-min conversion of .069 found HERE
Then again this disregards bends, transitions..etc which can increase flow at certain points so prol shooting for something in the middle would be best ;) :dsm:
