Tyeler18
- 2,568
- 368
- Dec 16, 2008
Casa Grande,
Arizona
I've done a relatively broad search (as well as read a huge amount of the tech articles on doing a 1g timing belt) and just can't seem to figure this out.
Background- 90 AWD TSI that I'm doing a headgasket/timing belt job on for a buddy (zanderson). We're getting it all put back together with all new OEM parts and we've gotten to timing the motor. We get the tensioner right in spec where we can pull the grenade pin out of our brand new OEM tensioner as well as fit the 5/32" drill bit between the arm and the tensioner. Torque the pull bolt down to 36ft/lbs and then wait for 15 minutes to check it again. Our problem is that after 15 minutes the grenade pin is tight again and the gap is too small to fit the drill bit in.
We've retimed it 5-6 times now and tensioner the pulley in different amounts and always the same result. After about 30 seconds you can feel the pin getting hard to pull as the tensioner begins compressing again. We aren't for sure how tight the bolt holding the tensioner arm on is supposed to be but we have it at 32ft/lbs trying to hold it.
Anyone else with this problem? Bad brand new tensioner? There's no oil leaking out of it.
Cliffs- timing belt job
Brand new tensioner won't stay within spec after 15 minutes.
