Passenger Window Stopped Working
ChvyKc
651
14
Nov 5, 2003
Cayce, South Carolina
Took the door panels off to try to fix the windows from going up crooked. I got that problem fixed, but now I can't get the passenger side window to do anything. Everything worked fine when I put everything back together. I check both windows and both of the switches before I put everything back up and after I put everything back up and they worked fine. I took the car out for a drive since I haven't driven it in a week and a half (coolant leak) and both of the windows were fine. I got back home and was making sure that the coolant leak was still fixed and all of a sudden the window does work, it doesn't matter which swith I use, the window will not move at all. The driver's side window still works fine.
Don't both of the windows work off of the same fuse? If the passenger's side window switch went bad would it make the switch on the driver's side for the window stop working?
The panel is off right now, I never put it back on after I took everything back off to check it after it stopped working. The harness that goes into the switch on that side is fine, it looks just like it did when I took it apart.
