driver window stopped working
GettinPaper
289
Aug 31, 2009
Battle Ground, Washington
My driver side window stopped working out of no where..
My passenger window still works so i know it's not the relay
and i checked the wires that go to the switch under the door panel
and it was fine... any help will be appreciated
Possible blown window motor? Have you tried using a volt meter to check the signal at the motor? It may just be the motor itself :hmm:
I thought my driver window was messed up to but it just ended up being that the whole button assembly was loose and when i pushed it to make the window go down it would fall down and not allow the button to be pushed... LOL just a thought
