meliketoball
- 1,505
- 5
- Jan 4, 2007
Bay Area, CA,
California
Can overheating cause oil to push out the engine?
Reason I am asking because a little coolant return line from the turbo busted and my car overheated. (temp gauge went 3/4 up the way.)
On the way home, my car dumped all of my oil on the ground and luckily got home just in time before the engine failed. I replaced my all of the coolant lines in the area and topped off the coolant and oil. Drove the around the block and everything was fine.
Car always had a little drops of oil dripping, for I have a crack in the valve cover. I also noticed pools of oil on top of the transmission after investigating and when it leaked oil, oil dripped down to the center member underneath the transmission.
Can running the engine hotter than usual force oil out of the engine?
Any suggestions? (CAS oring, VC, VC gasket?)
\m/
