Oil Ring Position
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
On the oil ring, does it matter which way it's installed? Whether the two ends point up or down?
IE: _/\_ or down like this -\/-
Does one way work better than the other?
no it dosnt matter, that is a waved spacer ring, and makes no contact with the cylinder wall at all.
I normally place the gap of the spacer in the center line of the wrist pin, then one oil scraper ring about 40*-60* to the left of the wrist pin and the other the same the other side of the wrist pin.
then in stall your compression rings and place the gaps 180* apart
make sure you place the rings on the right way, and check your ring gaps
