piston oil ring help
dj99877
87
Sep 24, 2007
LaCrescent, Minnesota
OK, probably a simple question to most of you but i did not get instructions with my ring kit and i want to make certain that I am doing this right. ok- for the oil ring there is 3 actual rings. 2 are flat and the middle one is a wavy spacer. anyways. on the middle wavy spacer where the two ends meet to make a complete circle are the ends supposed to face up like this _/\_ or down like this -\/- , or does it not matter. sorry for the bad diagram but I think you guys will get what I am trying to say.
Down on every engine i have built, also do not forget you put the rings in a triangle configuration. Hope i helped
Darren
