Oil Ring Gaps
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
I have 2g pistons with 1g rods with hastings rings. Is there need to gap the top and bottom oil rings? If so, what should I shoot for? Stock? If so, what are the stock gaps?
Well I checked them and they were really loose, around .025, this was straight out of the box. Why would they be so loose? Does hastings use looser oil rings?
how are you checking the ring gap? if you are cheching the gap correctly i would call hastings and make sure there isnt a mix up with your rings i had it happen to me once there was a screw up with packaging on a group of rings and i ended up getting a miss boxed set of non turbo rings instead of a turbo set.
