Oil restrictor!
chanley talon
773
14
Nov 10, 2005
Spencer, Indiana
Yes i have elimanated my b shafts and i have to much oil pressure does anyone have some photos or how to links on how to lower the oil pressure? I just need to get this joker fixed cheep . I cant go out and buy a big nice oil cooler . I just need to either add or remove or bore something out . Can you help? WTF
Where exactly is that found on the front case? Has anyone ever experinced a clicky oil pump? And what causes that just a side question . Yes if you have a photo or a link it would be much appreciated also if you know how far im supossed to port it out?
How much oil pressure are you seeing at operating temperature and what oil are you using?
Late reply, but hopefully not completely useless. Pull the oil filter housing, and do this to it (port the oil filter bypass, but make sure you don't take away so much material that the valve doesn't close fully):
