2G Oil pump timing
4g63Sneaky
Jan 3, 2026
san diego, California
i have a 1997 eclipse gst i was double checking all the timing and crank and camshaft are in time the only thing is the oil pump? i saw that the sprocket it broken but i also a circle but most of the videos i’ve seen on timing is a arrow and not a circle like mine would it be possible if the arrow broke off or is the circle mark the actual timing mark?
The blue circled dot on oil pump sprocket is the timing mark for you. The early oil pump sprocket comes with an arrow, and the late sprocket comes with a dot.
So in the pic, it's off, but keep in mind that all timing marks (cams/crank/oil pump sprocket/balance shaft sprocket) would be lined up only once for 6 crank rotations. And if you have eliminated the balance shafts, you don't need to care about that timing mark blue circled anymore. That timing mark is for the left (rear) balance shaft.
All come with an arrow now from Mitsubishi, building and engine for a customer and his OEM pump uses an arrow and is a 7 bolt also just to note.
I have seen both but most of the 7 bolts I have noticed are arrows my old OEM pump
All come with an arrow now from Mitsu, building and engine for a customer and his OEM pump uses an arrow and is a 7 bolt also just to note.
I have seen both but most of the 7 bolts I have noticied are arrows my old oem pump
They have a different part number, so it would depend which one you buy. Original is what I said above.
I bought the car about 6 months ago. Is there anyway of knowing if the balance shaft was eliminated?
Also would it be okay if I just set the time for the oil pump cause right now as it sits everything is in time except for the oil pump?
You can check the rear BS bolt plus on the back of the block as a way but also if you spin this without a belt on it you can generally feel if the BS is connected or not due to how lighter the sprocket is to rotate vs with the original balance shaft connected. Plus if it still has the BS it can fall level and self-rotate.
is there anyway of knowing if the balance shaft was eliminated?
If you have the balance shaft belt (the small one) you still have the shaft.
Like Bobby said above, if the LH shaft has been eliminated, you can't feel centrifugal force by the balance shaft counterweight when you spin the oil pump sprocket without the timing belt. It would just spin equally. If the shaft is still there you would feel centrifugal force easily when you spin it.
There is no way to confirm by the pic if they have been eliminated correctly by the previous owner. You eliminate the balance shaft means you would replace the LH shaft (the rear one) with a stub shaft or a race shaft, or cut the original shaft and block off the oil hole in the shaft. And if also you remove the RH shaft (the front one), you would need to block off the oil feed holes on the block by rotating the balance shaft bearings or just leave the sahft in its place.
also would it be okay if i just set the time for the oil pump ?
You should upload a pic to show us the timing just for in case. I don't know if you set the valve timing correctly but in case if it's off, you would easily bend valves in the worst case scenario.
the car ran before hand started up drove fine when i let the car sit for 2 days i notice timing belt was loose so before driving i just wanted to make sure everything was in time. and i saw the oil pump wasn’t in time. that’s why im asking the question what made me think it was out of time out of no where the car started shaking and boggling down and stalling. i just took more pictures it looks like the right balance shaft was deleted if im not wrong? would they have to delete the rear one also? or can one stay on?
Hiw did you notice belt was loose? If you say in between the cam gears that is not a reliable indicator. Regarding the oil pump the question cannot be answered by the pic except to say it kind of doesnt matter as you don't have the front shaft. It is unlikely you have the rear shaft.
Correct, the RH (front side) balance shaft is removed.
If the balance shafts have been eliminated properly, the timing mark on oil pump sprocket doesn't need to be set. It wouldn't affect performance as long as the crank/cam gears timing marks are set properly. If you still set it or not would be just personal preference.
The issue could be something else. But anyways you should confirm if the LH shaft is also removed or not just to be sure.
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Black Ashtray & Cup Holder
    2G Black Ashtray & Cup Holder $35 + shipping and paypal fees* both sides open and shut * all 4...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
  • For sale 4G63 2g/1g Parts
    2g 1g parts
    • rEclipserGST
