Deuce_three
- 451
- 5
- Jul 9, 2008
Lynnwood,
Washington
I bought a new oem oil pump, new oem oil pump bolt kit and bse. I'm just waiting for the machine shop to finish working my block and polish my crankshaft. Before I start, my question is what should I use for the oil pump bolts? Grey rtv, lock tite or other stuff? Let me know what you recommend. I'll be using copper spray this time for most of my gasket since ive read that it did help seal better.
With my Last build I had problems with the oil pump leaking in several places do to cheap paper gasket and improper front case bolt torquing.
