front case and oil pump questions.
codeofdastreets
505
3
Sep 25, 2008
dunedin, Florida
Im putting together my 4g63t motor and have a few questions. 1st question is what type of greace do I use in the oil pump to prime it? And where would I buy it? 2, On the 12mm bolts that hold the oil pump together do I use thread lock?? and those bolts get torqued to 14lbs correct?? what would the best thing to use to hold the plastic freeze plug in the front case for the bse?? thanks
I packed my oil pump full of vaseline so it would be primed on startup.
Alternately, you can spin the oil pump with a drill until oil makes its way up to the head before you put on the t-belt. That's what I will be doing this time...
so the gear to stubby 29-36??? or gear to oil pump 29-36?? 14 on the oil pump case correct?
Somebody else will answer I'm sure. This is not a smart ass question, but do you have a repair manual? All the specs are listed in it. If you don't have it why wouldn't you?
The vaseline by your computer, next to the rags will work :p Just kidding. Any kind of vaseline will work. Thats what I use on every build I do.
And yes please use loctite. I learned the hard way on my first build. I didn't loctite the oil pick up tube bolts and a year later one finally rattled out and chewed up my bottom end.
