oil pump front case question
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
You can reuse the front case itself but it's recommended to change the oil pump gears (drive and driven). Adding to your list, you may want to get a new crankshaft seal, oil pump sprocket seal, balance shaft seal, and oil filter housing gasket.
BTW, a new OEM front case usually comes with new gears and all three seals. The only thing you'll need to get is the castle plug and its O-ring.
so keep the front case and get:
crankshaft seal
balance shaft seal
new 2 gears
gasket
frontcase castle plug and oring
buy if I get a new front case, it will come with crankshaft seal, oil pump sprocket seal, balance shaft seal, and new 2 gears?
so if I spend the $205 for this....OEM DSM Oil Pump Front Case- 92.5-99 DSM 7 Bolt: BoneHead Performance
I will just need the gasket and castle plug and oring?
crankshaft seal
balance shaft seal
new 2 gears
gasket
Yes, you'll also need a new oil filter housing gasket along with the front case gasket.
Yes, that's everything. If you have doubts, just give Bonehead a call. I had to call Extreme PSI to find out that the new OEM front case came with all the seals and the gears.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
