dsm-onster
DSM Wiseman
- 8,592
- 130
- Jul 11, 2004
Bloxom,
Virginia
There's very few ways to find clogged ports without knowing pressures relavent to spec. It doesn't take alot of gunk to alter oil flow to the head. Also, we buy these motors with several head resurface jobs done to the head. This has a significant affect on the minimum port area to the head. As well, a sticky oil relief valve or a weakened spring has nothing to do with the quality of the build, but does alter perameters that certain components see. and thus, it can be beneficial to know what these perameters are directly. . . Instead of saying 'hey, this 500 lbs of thousands of different interacting systems are jsut going to function just right. No need to check in as many points as possible.'
Glad you will stop this "with me", considering this isn't my thread. This guy has fairly good reason to wonder what his oil pressure is at the turbo. It's an important aspect to turbo longevity. Good-bye, if all you're here to do is say it's 'idiotic' take steps to quench your concern, . . . because of possible leaks? Come on. I'm sure he knows how to choose sealing fittings and tighten them.
