turbotalon1g
- 1,076
- 39
- Oct 19, 2005
Blaine,
Minnesota
Ok, I basically drove myself insane looking at part #s of fittings and fitting sizes and junk, so I figured I would ask you guys for some help.
I want to make something to measure the oil pressure at my turbo inlet.
Now I use a -4AN line to 12x1.5 fitting, the top of this fitting has been turned down so that I can use nitrous jets as my restrictor.
So i need something that will accept the 12x1.5 thread, accept a 1/8NPT thread (thread most commonly found on small pressure gauges) and output (male) 12x1.5 to screw into the turbo.
Maybe there is another way using different fittings and adapters to do this, but I am having troubles figuring this out.
I appreciate the help, especially as I should be concentrating on my new OJT rather than my car.
Thanks again
Aaron
Thanks again
Aaron
