Buying a turbo, help me out~!
That looks like maybe a 13g to me. Mitsu turbos use TD04 and TD05 compressor housings. The TD04 is the smaller ones (like the 13g), TD05 is 14b, 16g's, and the 18g, then you can get a 20g in TD05 or a larger TD06H housing.
13g's came in 1g automatic tranny cars. They are really small. Good luck!
Ya I second that, not a 16g, probably a 13g. You can't tell 100% as the numbers aren't clear in the pics but like mentioned above the TD04 on the comp cover & if you look at how much material is around the comp cover inlet (thickness), the amount on a 16g is much less.
B,C, and A wheels have uniform blade spacing while the G's are doubled. That is definately a 13G.
the td04 can also be a 14b that came off an automatic 1g turbo, but is not a 16g for sure!
There is no such beast as a td04 14b. And that is a g series compressor wheel, not a b series. As already stated many times, it is a 13g.
