Spyder oil pan type
Jaydiz
Aug 12, 2023
Pardeeville, Wisconsin
i have a 96 fwd automatic spyder gst, i busted my oilpan and need a replacement, all the ones under 100 dollars arent the right one as mine has a curve on the pan, the ones i can find with a curve are 250-400 dollars. is this just how it is or can i find a normal priced one somewhere
2g turbo oil pans are harder to find than the 1g, which is still produced by aftermarket companies. IDK why they aren't reproducing 2g pans as well.
Careful if you're shopping on RockAuto, as they list the 420A oil pan on the parts list for 2g 4G63 vehicles. The 4G pan has a different bolt pattern and is not interchangeable. It might be best to report this to RockAuto, as it's very possible and easy for those who are oblivious to end up with the wrong part.
I might have a spare. Will need to look after work.
thatd be dope lmk
i can find a few but none that arent 300 dollars and that just seems crazy
That is probably normal and the ones you're seeing are 420a. Did you try the dsm vendors/junkyards?
i called 3 junkyards no one has eclipses, and ive found a few online sites but literally there all crazy expensive
    • Sdcryan1
