2G Oil Level Light Turns on randomly but oil level is fine
Adam4155
May 3, 2019
East Rutherford, New Jersey
So I have a problem, When I'm driving my oil level light randomly turns on then sometimes turns off at low rpm's. Also I have a oil leak but I'm not sure where from, my oil level is also fine.
I have 1996 2g Eclipse N/A
Check the alternator, common problem when it's going bad to set those lights off if the charge output is too low.
Can also double check the battery and cable connections to be sure, but I'm betting the alternator is giving up.
Ive check it and its seems to be getting good numbers.. The ABS light also turns on randomly also
