oil filter housing question...
can i install oil pressure sender in either of those bolts right there? the top one i think is stripped out.
if i were to buy a 90 oil filter housing can i block off the external bolts til i buy the cooler?
also, does anyone know if the wire taht connects to the dummy sender is blue or yellow?
Why dont you use the head for oil pressure? there is an extra hole that you can use on it were the stock oil feed line is.
